Failed to initialize for explicit ifIndex.
This is an internal socket library issue. Please try the following: check protocol and interface configuration, restart the protocol, reboot the system. If the event still occurs then contact technical support with the output of "show tech".
Warning
Failed to initialize for explicit ifIndex. Socket ID = %p1% Socket type = %p2% Socket family = %p3% Socket protocol = %p4% Stub socket handle = %p5% Application socket handle = %p6% IF index = %p7%
| Name | Type |
| p1 | sInt |
| p2 | xInt32 |
| p3 | xInt32 |
| p4 | xInt32 |
| p5 | uInt32 |
| p6 | uInt32 |
| p7 | uInt32 |
